Bela Subwoofer?
Discussion in 'Speakers' started by MikeGee, May 19, 2005.
  1. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    At a local DIY store that sells alot of home audio do it yourself gear. They only carry one brand of woofer for home theatre application and its a brand called BELA. I've never heard of them and cant' seem to find them online.
    Appearances of the speaker seem to be awesome. the magnet is huge , the rubber of the woofer seems quite sterdy, and it isnt made of cheap paper.
    Its 280watts RMS which would be run through a 300watt RMS plate amp for a project sonotube i'm building.
    The speaker itself is 130$ canadian.
    The amp is 219$ canadian.
    Anyone herd of this company before tho?
  2. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    I wonder if it's made by The Canadian Loudspeaker Company.
    Brent
  3. MikeGee
    MikeGee Second Unit
    Dec 11, 2004
    292
    i guess nobody has heard of them. I'm just debating with myself whether doing the whole sonotube + 12" Bela sub would out perform a already built sub from future shop for the same if not cheaper price.
  4. brentl
    May 7, 1999
    2,921
    Try it, is the sub is shitty you can always upgrade to a known woofer!
    I'm sure a properly built enclosure will kill anything Future Shop or BB has for sale.
    Brent
