Probably not very well, John. I think the lowest frequency setting on the BFD is 20Hz. If you set too wide a bandwidth you will get into the critical frequencies. Too narrow and all you have is a notch; everything below it will still be there.
A subsonic filter should be shelving. Some parametrics will let you do this (like the Ashly models), but not the BFD.
You might try experimenting with the bandwidth setting using a test disc and SPL meter to measure the effects. Maybe you can make it work, depending on your sub.
