ezonebroker
- Sep 25, 2010
- Chris
I have a basement room that is 17'X25' with a Trey Ceiling that is 8' to trey and a little over 9'. My equipment that I have now is and Harmon / Kardon AVR2600, Jamo 5.0 entry level and a 10year old 100watt self powered JBL subwoofer. Also, Dish Network, Apple TV, and an Xbox that I have used maybe 5 times. Further, I just bought an LG BluRay player, my first one.
Because I have a trey ceiling I am running into set up issues in many areas. My seating area before the two metal support polls is 11' to 17'4" with the future plan of a bar behind that with some stools for extra seating during football games. At first I am starting with just 3 theater recliners and then if I have room, 3 more elevated behind and then the bar behind that. Lastly the fridge and a small kitchen area on the back wall. I have never had a home theater projector, so I am flying blind.
Advice on the follow would be most appreciated:
* Is it ok to just use regular speaker wire that is 12 awg. the chase and some wood studs or do I really need in wall wire?
* Would I only need a power receptacle and an HDMI routed to the projector? Should I use the DataCom or something else for projector in ceiling?
http://www.amazon.com/DataComm-45-0021-WH-Recessed-Voltage-Cable/dp/B001C4EAL8/ref=sr_1_3?ie=UTF8&qid=1371219208&sr=8-3&keywords=home+theater+plate+datacom
*Which of these projectors would work best for that size room, for watching college football, hockey and movies? I guess buying a projector ahead of finishing helps in determining where to a connection in the ceiling?
Epson PowerLite Home Cinema 8350
Mitsubishi HC4000
BenQ W1070
ViewSonic Pro 8300
Any other suggestions?
*What screen would be a good match? size? color? gain? I am pretty good at DIY so that is not out of the question if decent quality can truly there in a DIY screen.
*Is this sufficient behind the receiver? What works best for the receiver and for speakers if I go with all wall mounted instead of inwall?
http://www.amazon.com/Vanco-HTWP72BW-Whole-House-Theater/dp/B001702I1Q/ref=sr_1_1?ie=UTF8&qid=1371219372&sr=8-1&keywords=home+theater+plate
*Suggestions some decent in wall speakers for my the side and rear speakers? Or should I try to avoid that?
*The AVR 2600 allows for a 7.1 system, but I don't know if I should place the rears all the way on the back wall?
*Have you found it a pain your equipment all put in a utility closet, I have that option under the stairs?
*What have you found to be good sound deadening insulation to put in the ceilings and walls under the sheetrock?
*I would like to make this upgradeable in the future, so I am trying to avoid the mistakes upfront...
Attached are some pictures with the hopes that I might get some suggestions on what to do and buy next to get this thing up and running.
Thanks in advance,
Mitsubishi HC4000
BenQ W1070
ViewSonic Pro 8300
Thanks in advance,
