I'm evaluating TV stands/media consoles to replace my old chrome, black metal, and glass TV stand and am wondering if anyone here at HTF owns any BDI products. I've had a helluva time finding acceptable candidates due to some unique requirements. I have an Onix Rocket front soundstage set up, including the massive RSC200 center channel speaker, affectionately known as "Bigfoot." It's currently sitting on the floor UNDER my TV stand's bottom shelf. Not an ideal placement.
I've given up trying to find a cabinet or stand that accommodates the CC internally AND looks good in a living room. So, I've decided to wall-mount my 77" LG G3 OLED panel and place the center channel ON TOP of a new media console. I don't want to mount the panel too high on the wall, so a low-profile cabinet that will fit my two 4K players (an Oppo UDP-203 and a Panny UB9000) and my AVR (a Yamaha RX-A8A) seems like a good way to go.
The BDI Corridor 8173 fits the bill, and I can even fit the RSC200 *inside* the center compartment if need be. It's only 21" high, which will keep the height of my wall-mounted TV within acceptable range. I saw one in-person today at a local Copenhagen furniture store and liked it quite a bit. It will work. The problem? It is DAMNED EXPENSIVE. Almost $3K for this beast!
Before I make a decision on whether or not to pull the trigger on what very well may be my only real option that's both functionally acceptable AND a very aesthetically pleasing piece of living room furniture, I thought I'd ask and see if any of you can chime in if you own a BDI product. Any feedback is appreciated. Thanks.
www.bdiusa.com
Corridor Media Media Console 8173
Perfectly sized for home theater systems with a large television, this modern TV stand and entertainment center packs a ton of innovative features into a low profile design, including a soundbar shelf, remote and audio friendly louvered doors, built-in cable management, adjustable shelves...
