stephen abbot
- Sep 28, 1999
David, lets compare apples with apples here.
I would suggest that if you were to play a DVD that was infact at 25fps (ie a disc of 25fps video material) on the Malata then you will get some pretty annoying temporal effects that you would not get from a broadcast quality conversion process.
However when you play film sourced DVD's then you will get the same result (in temporal terms) as if you played an NTSC disc on the machine as DVD's of films are normally encoded at 24fps regardless of the final playout standard. The only thing the Malata must do in this case is perform a simple spatial scaling job to reduce a 720x576 frame to 720x480. Because this is a reduction in resolution it is hardly surprising that the end result looks good by NTSC standards.
Regards
Stephen.
