Bathroom reno: Toilet discussion
Discussion in 'After Hours Lounge (Off Topic)' started by Jeff Ulmer, Mar 23, 2005.
  1. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    Yes, I know it's a crappy subject, but I need to replace my current toilet, and am looking for some advice.
    I am on a septic system, which has been failing due to my current toilets leaking all the time. The cost of reparing them doesn't make sense, so a new unit is in order.
    My question comes down to choosing between a 6L or 13L tank. While the 6L would be better at helping the septic system due to less water, I am concerned about flushing power. If I have to flush twice each time it defeats the purpose.
    I am looking at getting a Crane (Cadet or Radcliffe), since I will also need to replace my tub soon as well, and I want it to match.
    Thoughts?
  2. MarkMel
    MarkMel Screenwriter
    Nov 19, 2003
    1,875
    116
    1,610
    Look at american standard's champion models. Really good flush.
    "It's like a jet plane in there Jerry! A jet plane!"
  3. Jeff_CusBlues
    Jeff_CusBlues Supporting Actor
    Jun 19, 2004
    605
    How about a Ferguson?
  4. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    One problem I have where I live is limited access to models, so if I want something that isn't available locally I am paying through the nose for it.
    I also need to have matching tub and sinks available, since they are all in close proximity. White is a really hard color to match between brands.
  5. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I forget which brands, but they do have power flush models that work well and use limited water. Go for the guy models with the elongated tanks. Better for our aim.
    Sorry to hear about your septic. That's going to cost big time to redig it. There's a company that I've heard about that's had some fair success with rejuvenating the leach fields (I'm assuming the feeder tubes going to it are in good repair) where they inject polystyrene beads under the ground under enormous pressure. This causes fracturization of the soil underneath and the beads keep things separated to allow for improved drainage.
  6. Dennis*G
    Dennis*G Supporting Actor
    Oct 7, 2003
    524
  7. MarkMel
    Nov 19, 2003
    1,875
    116
    1,610
    Are you in the US? If so, there are several online sites that I have delt with for all of my bathroom fixtures, from faucets to toilets and tubs, all ordered online.
  8. Scott Wong
    Scott Wong Second Unit
    Oct 30, 1999
    421
    Mark:
    Any links you might be able to provide of reputable online shops you've dealt with??
  9. LanieParker
    LanieParker Supporting Actor
    Apr 15, 2004
    735
    May I suggest a compost toilet. I've been looking into them for a while now and I think I am going to get the Naturepost model. Many homesteaders I know or have talked to say it is the best on the market.
    Bioron also sells them too for really good prices.
  10. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    I am in Canada. I have been advised to get the 13L version, since with the 6 you end up flushing twice anyway. I will be getting a Crane.
    The septic fixing shouldn't be all that expensive, but it is requiring a lot of excavation to figure out where everything is.
  11. MarkMel
    Nov 19, 2003
    1,875
    116
    1,610
