bass shakers
Discussion in 'Speakers & Subwoofers' started by Mark Nguyen, Oct 23, 2005.
  1. Mark Nguyen
    Mark Nguyen Stunt Coordinator
    Sep 26, 2002
    174
    Hi,
    I am looking to setup 6 bass shakers and was wondering how many wires I need to run for them.
    P.S. Any suggestion for a fairly cheap set of 6?
    Thank you,
    Mark
  2. Jon Bell
    Jon Bell Stunt Coordinator
    Jan 14, 2001
    170
    Mark,
    My setup has 6 shakers. I run them from a standalone speaker with the left speaker wire running 3 and the right running the other three. The regular Auras are roughly $25 per pair and you s/b able to pick up a receiver or amp pretty cheaply. Go to the AVS Forum and look in te speaker discussion and you'll be able to find out more than you'll ever need about different wiring options (i.e., wire them in series, parallel, etc.).
  3. Mark Nguyen
    Sep 26, 2002
    174
    Thanks Jon, will check them out.
    As for the cable, is CAT5 adequate for drive these shakers? I have plenty of CAT5 laying around and figure I would use those instead of buying more speaker wires.
    Mark
  4. Jon Bell
    Jan 14, 2001
    170
    I don't know anything about using CAT 5 to drive speakers. I used plain ole home depot in-wall speaker wire. You definitely don't need anything fancy.
  5. Brad_B
    Brad_B Auditioning
    Jan 20, 2005
    5
    Be aware that the regular Aura's being sold by PartsExpress right now are really crappy white box versions. You even have to solder wire to them manually. They do not carry the retail version of the regulars any longer.
  6. rob-h
    rob-h Second Unit
    Jul 6, 2005
    263
    brad, can you post a pic of what you are talking about?
