bass shakers and connections
Discussion in 'Speakers' started by dan scorpio, Nov 1, 2003.
  1. dan scorpio
    dan scorpio Stunt Coordinator
    Jan 19, 2003
    56
    someone said you can use a old amplifier to use for bass shakers.... but how do you connect it to the old receiver?
    do you connect it to the cd input or any input?
  2. ScottCarr
    ScottCarr Second Unit
    Jan 28, 2003
    459
  3. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    You can pretty much use any input. YOu can use one channel or split the signal and use both channels if you wish. Should work fine.
  4. dan scorpio
    Jan 19, 2003
    56
    yes i tried that, i connected it to the cd input,then dvd input and nothing happens.....i will return that receiver
    i then found a old piss of crap receiver from the 70's and hooked it up to the phono input and now it works...
    the only thing is if i turn it up i get the male voices talking and shaking 9not verry good) so i ordered a 50 hrz lowpass f-mod to corect that.......
