Ken Woodrow
- Feb 12, 2001
I'm looking to get the best subwoofer performance possible out of my 10x17 HT for music and movies. My principal constraints for subwoofer choices are LOCATION (only one or two places to put a sub, both in the back corners of the room) and INTEGRATION (I need the subwoofer to integrate seamlessly for both movies and music, with the emphasis on music).
I'm 98% sure that I will be going with a SVS sub. But several questions remain, given the limited flexibility of most pre/pros to handle bass management:
1. What has the most versatility in terms of integrating the sub with the main speakers -- an active multi-channel crossover unit, like the Outlaw ICBM, or an equalizer, like the Symmetrix or ART sold by SVS? I realize that the equalizer works only on the bass channel and that the ICBM lets me set different x-over points for different speakers, but all five of my speakers are identical and are basically flat to 70 Hz. So far, I don't have DVD-Audio or SACD, but may in a future upgrade.
2. What advantages does outboard amplification have over a powered (PC series) sub? More headroom?
3. What is better for music, a CS Ultra or CS sub? Particularly in terms of speed, accuracy, integration, etc.
Thanks so much.
- Ken
Thanks so much.
- Ken
