Bass level difference between theaters and home theaters
Discussion in 'Archived Threads 2001-2004' started by LawrenceK, Nov 21, 2001.
  1. LawrenceK
    LawrenceK Stunt Coordinator
    May 19, 2001
    116
    Whenever I go to see a movie at the theater, it seems that the bass is toned down much lower than I have it set in my HT. Members on the forum describe various passages in movies where you should "feel the bass", and I can definately feel these key scenes on my setup (which is calibrated using Video Essentials), yet I rarely remember feeling, or hearing, that kind of bass in the movie theater. Now before you dismiss it as "the theaters have it set incorrectly" I would like to state that the theaters I am comparing my HT to are VERY nice and were just recently redone. So I guess my question is: is everybody on the forum just listening to setups with way too much bass? Do the theaters have it correct, and should I aim for that kind of sound in my own HT? Right now it seems to me like the theaters have the more balanced sound...please let me know what's going on..
  2. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
    No matter how carefully it's calibrated, a "near-field" HT environment will never sound the same as a large auditorium. Think about where you're sitting in relation to the subwoofer(s) in each location. When you're at home, the bass waves are emanating from a source much closer to you, and they don't have to pass through dozens of additional seats and bodies before reaching you. It's not surprising that you "feel" the bass more at home.
    M.
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    I think the bass in theaters rolls off much earlier than a typical ht, maybe good down to 30Hz or so.
  4. Mario_C
    Mario_C Stunt Coordinator
    May 15, 2001
    83
    The other thing to consider is that most people in this forum run their sub(s) 6 to 12 dB hot. I just to run my sub 6db over when I first got in HT. Over time I got tired of the bass heavy sound, and back down my sub at the same level as my mains.
  5. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    Also, your home isn't as acoustically neutral as most movie theaters are designed to be... unless your home is made of cinder block and thick curtains. [​IMG]
    Room acoustics can boost certain frequencies and nullify others, so I'm sure that's part of the difference. And if not, well it sure sounded good!
  6. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    I don't think it's as complicated as most here have described.
    I think it's just that most theaters have modest or inadequate subs for the size of their rooms.
  7. Holadem
    Holadem Lead Actor
    Nov 4, 2000
    8,967
    I know of a couple of theaters in NYC where you can definitly feel the bass. Most of the rooms are THX certified.
    68th Lincoln Sq - room LOEWS (THX)
    Loews Kips Bay - room 10
    14th Union Sq - room 8 (THX)
    ...come to mind. There are others.
    Eben my 20-39PC does not punch me in the chest like ch 29 of the matrix or Episode I did in those rooms. On the other hand, I feel vibrations much better in my room - hardwood floor and all.
    Holadem
  8. Jim Robbins
    Jim Robbins Stunt Coordinator
    Sep 3, 1998
    233
    I agree with Philip and I beleive many theaters keep bass controlled to prevent interference in ajoining units. I have never heard bass in a theater (not even IMAX)that goes as low as my sub.
  9. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
  10. Jack Gilvey
    Mar 13, 1999
    4,948
  11. Michael Reuben
    Feb 12, 1998
    21,763
    3
    5,110
    While I agree that many theaters have inadequate equipment or limit their volume or frequency response, there are theaters that don't (Holadem gave some good examples). And even those theaters will sound and "feel" different from a well-calibrated HT. Near-field is just different.
    M.
  12. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    A small room is going to have a lot of modal standing waves in the bass frequencies.
  13. Jimmy P
    Jimmy P Stunt Coordinator
    Jul 1, 2001
    82
    To be honest,most people have their sub or subs set way to
    high (level).This sounds impressive for showing off their
    hardware,but its not very natural sounding or accurate.
    Since you are the one that has to be pleased,set it where you like.[​IMG]
  14. Lewis Besze
    Jul 28, 1999
    3,134
  15. Jon_B
    Jon_B Screenwriter
    Nov 27, 2000
    1,025
    My ht room is much, much, much smaller than a cinema plex. Because of this I have a lot of bass. I have my sub turned down to -11 on my reciever in an attempt to try and correct this.
    Jon
