bass EQ
Discussion in 'Archived Threads 2001-2004' started by Bill Polley, Jun 19, 2002.
  1. Bill Polley
    Bill Polley Second Unit
    Apr 18, 2002
    252
    Can anyone recommend a good bass EQ, either tightly spaced graphic or decent parametric? I could use some help with a room that needs taming. Thanks.
  2. Craig Woodhall
    Craig Woodhall Supporting Actor
    Jul 11, 1999
    590
    the one and only, behringer feedback destroyer.. do a search on bfd and you will find tons of info on it.. Fully-adjustable, can do dual subs, and you can dial in pretty much any frequency you need to tame.. or boost [​IMG]
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,265
    72
    9,110
    Corpus Christi, TX
    Wayne
    Bill,
    Craig’s right – the digital parametric BFD is your best option for the money – as cheap as $125 at some outlets. Any "decent" analog parametric will cost more than twice that much (as long as we’re talking "new" prices).
    Regarding graphics, you can get some budget 1/3-octave models for a little more than the BFD. However, the only ones with “tight” filters are high-end professional models – we’re talking $1-2000.
    Wayne A. Pflughaupt
  4. TedO
    TedO Stunt Coordinator
    Dec 17, 2001
    143
  5. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    I would avoid the graphic EQs... you'll need to cut or boost very narrow frequency bands (1-2Hz wide). The other frequently mentioned parametric EQs are from Rane, Symmetrix, & QSC. Although more expensive, these work well at frequencies >1kHz. I A/Bd the Rane and BFD and couldn't hear any differences (for LFE use).
