JulianBrock
Grip
- Sep 11, 2002
I recieved my Tempest and finished my box... but for some reason.. I felt the bass was lacking. It sounded great if you put your ear near the sub. I moved the sub into a cubby hole in my room (hard to explain but I can take pics)and the bass increased 10 fold. I don't have any leaks. When I push down on the speaker.. it is very slow to release and I fed a 10hz tone into it to hear any leaks from the baffle. Anyone have any problems with room cancellation? Does this even sound like bass cancellation? I have a 230l box with 64oz of poly on a PE 250watt amp. If I can't get it to bass due to cancellations... is my only other route building another Tempest? Below is my install process... I think I have all other bases covered. I even used a battery to verify that the + and - are marked correctly on the speaker.
I have the + linked to the + on both vc as well as the -. I then have the + and - off the amp going to one of the vc.
I also disconnected my mains (alesis monitor 1's) just in case those were cancelling.
http://www.txraves.org/~magnetik/diy/Page.html
Oh.. also.. how long does it take to breakin the Tempest? also.. will it be real noticeable once it does break in?
Thanks in advance!
Julian Brock
Thanks in advance!
Julian Brock
