Bass boost in LSPcad (1 Viewer)
Jedd
How do I model bass boost in the LSPcad?
Like this (sealed Tempest, 150L)?
I'd like to keep 1dB boost at 20-24Hz, so it will help room response to flatten the curve. And I doubt that I will ever need
Jeff Rosz
hi jedd,
you can try going into the parametric equalizer section of the program and set one of the bands for 1dB boost @ 20-24Hz. i'm not up on the amp mod stuff, so i dont know the width of the boost to add. i'm sure someone will post the bandwidth for you. play with different settings and then look back at the response graphs and see whats happening.
Jedd
That's about what I did:
put 20,21,22,23,24 Hz into equalizer and boosted each for 1dB (the picture is above).
But I never did it before, so I'm not sure if I did it right and cannot estimate the curve.
davy2
