Patrick Fagan
- Apr 12, 2005
I'm not a techno-wizard. I need what I think is some simple advice. I'm about to purchase the ONKYO HT-S780 (7.1) and hook it up to a front projection Home Theatre setup in my basement. I'm pre-wiring before I put in the drywall, so I want to do the wiring right.
What type of wires should I use? Please use layman's terms! I need all suggestions--everything from the type of speaker-wire that I need to all other connections that will give me a good sound and picture, assuming that the projector will be run through the receiver.
Thank you in advance for your help.
