basic TV/Receiver connection question
Discussion in 'Archived Threads 2001-2004' started by Josh.L, Jan 26, 2003.
  1. Josh.L
    Josh.L Agent
    Oct 5, 2002
    31
    I'm not sure if i'm asking this question right, but here goes: I want to be able to watch TV and listen to the audio through my stereo's speakers. How do I do this without having to turn on my VCR(which I am doing now) And can I keep the DVD player hooked up as it is now with the video components going directly to the TV?
    As you can probably tell, I'm a little confused. I have a Sony 34XBR800 and a HK AVR 320
    Sorry for the newbie question, I just don't want to screw anything up, so I thought I'd ask.
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Hi Josh.
    Well... you have to have SOME device that gives you the TV audio that you can pass to the receiver. This can be:
    - Your VCR (like you have now)
    - The L/R jacks from your CATV box or Sat receiver
    - The L/R audio OUTPUT from your TV (if it has this)
    The easiest is if your TV has audio outputs. You want the "fixed/non-variable" output if you have a choice. (This way the TV volume does not affect the volume through your speakers.
  3. David Von Pein
    David Von Pein Producer
    Feb 4, 2002
    5,748
    10
    I don't know if it helped Josh any....but I gained from your post, Bob. Thanks. [​IMG]
    I'm kinda new as well to this HT game.
    Can I impose for another Q?? ..... I'm getting my first TV that actually has component input capability, and I'm wondering how much of a picture-quality leap I'm going to be making when I get my new set soon.
    I'm currently using the worst of the 3 variants (composite video input) going to my current TV.
    So, I'll be jumping completely over the "middle man" (S-Video) as far as quality is concerned, and going to what I've heard is the BEST possible video connection: Component.
    Do I have this staircase of quality correct? Composite provides the weakest picture quality; then S-Video; then component for the ultimate?
    Is my leap from composite straight to component going to be dramatic? (Esp. when combined with my first TV capable of doing the 16:9 squeeze for DVDs?)
    (Now I need component cables don't I? Are these cables expensive? And what brand do you guys recommend for best quality video?)
    Thanks for your assistance.
    [​IMG]
  4. Greg-ST
    Greg-ST Stunt Coordinator
    Jan 27, 2003
    193
    David, you should see quite a nice jump in picture quality going from a composite connection to component connections. From s-video to component isn't quite as large of a jump (basically s-video is a component signal as well, but not as pure as RGB).
    Sometime around May/June I'll be getting my first TV with component capabilities as well. I really can't wait [​IMG]
  5. David Von Pein
    Feb 4, 2002
    5,748
    10
    Thanks, Greg, for the info. [​IMG]
    To be perfectly honest, when I ordered my new TV, I didn't even realize it had the component capability.
    But, upon researching the advantages of such a connection, I'm certainly glad to have it.
    Greg ... I went with a Toshiba RPTV. What will you be getting in May? (I betcha you'll get it sooner! [​IMG])
    BTW, Greg, I LOVE the Cincinnati Reds in your hometown! [​IMG]
    Used to visit Riverfront often.
    Sadly, now it's dust.
    The new park looks nice though. [​IMG]
  6. RobertCharlotte
    RobertCharlotte Supporting Actor
    Feb 21, 2002
    660
  7. David Von Pein
    Feb 4, 2002
    5,748
    10
  8. David Von Pein
    Feb 4, 2002
    5,748
    10
    Then, too, there's also the ol' rabbit ears connection.
    Anybody still use those?
    [​IMG]
  9. RandyMe
    RandyMe Auditioning
    Jan 11, 2003
    11
    I could use a little help on this one myself...
    I have a CATV Box - 1 Coaxial from the box to the TV (No S-Video or Component outs on the Box) & 2 L/R Audio RCA's from the CATV Box to the Receiver's CATV inputs.
    Then a DVD with an S-Video going straight to the TV & 2 L/R Audio RCA's from the DVD to the Receiver's DVD inputs.
    CD Player is just the 2 L/R Audio RCA's from the CD to the Receiver's CD inputs.
    Does this seem OK?
    PS: I'll be replacing the DVD next week with the new Philips DVD963SA with SACD. Will I need to change the way the DVD is connected to make best use of the SACD?
  10. Mike Matheson
    Mike Matheson Second Unit
    Jul 15, 2000
    416
    Randy,
    Sounds like you've done the best possible with your CATV.
    I wouldn't sweat your current DVD connections with the 963 coming next week. But with that unit, try to run a digital connection (optical or coaxial) to your processor for digital audio. If possible run component cabling instead of S-vid for video to your TV. And for SACD &/or DVD-audio, you'll need a slew of normal RCA analog audio type cables (maybe six).
    What receiver/processor are you using?
    Any your CD player doesn't offer a digital output?
  11. RandyMe
    RandyMe Auditioning
    Jan 11, 2003
    11
