Basic 2 channel amp? (1 Viewer)
zaydenam
Zayd
Hi,
I'm looking for recommendations for basic 2 channel amps which are priced at ~100 dollars. I need the amp to run a pair of bookshelf speakers I'm making for my room. A 100 watt amp would be more than adequate (50 watt per channel).
SO far, I'm looking at the Audiosource amp-100. How does this amp fare in audio quality?
Would I be better off building an amp from a kit? Any examples?
Zayd
Dan Driscoll
What is your source and how are you planning to control the volume? If you have multiple sources what will you use as an input selector?
zaydenam
Zayd
My source will be lossless audio (rips from CD) from a hi quality mp3 player
Input selection is not really a priority for me right now, because I would much rather spend that money on a amp.
Philip Hamm
Not sure how (if) plugging an MP3 player directly into a power amp's going to work.... Assuming it works fine, check out J & R Music World, they the AudioSource AMP102 stereo power amp on sale right now, I just ordered one for a proper two channel preamp-power amp combo system. Also, checkout "integrated amps" - these are preamp+poweramp in one box, very minimal switching/other stuff.
http://www.jr.com/audio-source/pe/ASO_AMP102/
JohnRice
Bounded In a Nutshell
A Mile High
Theoretically, a power amp can work because the mp3 player can control volume, but I'm not sure it is a good idea. For one thing, if the amp is turned on when you plug in the player, you are likely to blow your speakers. I would find a used integrated amp.
Mark Sherman
I'd say the best bang for the buck is the Pioneer a A35R. Its an intergrated amp with a SOLID 50 watts per channel. Priced around 250 new around 175 used.
Jim_F
I'm using the Audiosource Amp100 (which is equipped with a volume control) to power my patio speakers. I stream audio to it via a WiFi access point. It serves the purpose fine.
$100 well spent here.
MusicLover95
