Basement remodelling - Speaker placement.
Discussion in 'Archived Threads 2001-2004' started by James_Buck, Sep 17, 2001.
  1. James_Buck
    James_Buck Auditioning
    Aug 21, 2001
    2
    I'm currently remodelling my basement HT which was a 25'L x 10.5'W room to an "L" shape room which is still 25'L x 10.5' plus a 10'L x 4'W section. The room is 10.5' W on one end, 14'W on the other. 25'L on one side, 15' then back 4' then another 10'.
    This was done to add more width to fit a 155" x 107" L sectional couch.
    The problem I am having is with the surround speaker placements. Its a 6.1 (or 7.1) system with side and rear surrounds. The rear surrounds are ok, but the side surrounds are the problem. One side surround will have to be placed inside a 4' section due to a door going on the 10' wall.
    Won't this cause problems? I was planning on getting bipole speakers (Paradigm ADP-370's) for the sides. Maybe I should just get regular forward firing speakers instead?
    Please help......
  2. Robert A
    Robert A Stunt Coordinator
    Feb 20, 2001
    57
    All Dolby Digital processors allow for you to adjust the time delay or level of the speakers to compensate for distance inequalities. Refer to your owners manual for a better explanation on how to do this with your reciever. Ideally though, you want the distance from on side speaker to be the same as the other.
  3. James_Buck
    Aug 21, 2001
    2
    I haven't played with my new receiver yet (AVR 5800), but I thought that the timing adjustment was for adjustment between front and rear speakers, not right and left sides
    I guess I was more worried about the side firing bipole speaker firing directlyinto a wall?
