Jeffrey_S
- Jan 17, 2002
Hi all,
As a follow-up to my last thread, I’m down to the following choice. Should I make the following:
My only hesitation with this beast is that it will stand about 83” tall. The following is a cost estimation:
2 Tempest drivers$300
HS500 Amp$500
BFD$130
Sonotube$ 75
MDF$ 30
Baltic Birch$ 20
Misc.$ 20
Total: $ 1,075.00
I could probably find a cheaper alternative for the amp.
Or should I make this:
The following is the cost estimation for this sub:
One Blueprint 1803 driver$280
QSC RMX 1450 amp$400
BFD$130
Sonotube$ 55
MDF$ 30
Baltic Birch$ 20
Misc.$ 20
Total: $ 935.00
I’m going to need a BFD either way due to room considerations. So I guess from a cost analysis, the price for each sub is similar enough. Of course, from what I’ve heard, I might have to live with fan noise with a QSC amp.
This sub will be used for about 70% hometheater / 30% music. I am mostly concerned with hometheater sonic punch.
So what do you guys think? Which one would you build and why? What amp would you use?
Thanks again to everyone!
HS500 Amp$500
BFD$130
Sonotube$ 75
MDF$ 30
Baltic Birch$ 20
Misc.$ 20
Total: $ 1,075.00
BFD$130
Sonotube$ 55
MDF$ 30
Baltic Birch$ 20
Misc.$ 20
Total: $ 935.00
