base plate for downward firing sub?
Discussion in 'Archived Threads 2001-2004' started by Jason Wilcox, Apr 7, 2002.
  1. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    I have a JBL 8 inch 100 watt subwoofer. It is a downward firing sub and I have it on some thick carpet. Would it be a good idea to place some type of base plate under the sub? (like a piece of slate) Or would this make no difference whatsoever?
  2. Cave Canem
    Cave Canem Auditioning
    Mar 8, 2002
    14
    From what I was told and what I have read when I went sub shopping, a carpeted floor with a down firing sub, the carpet is going to absorb most of the bass. Im not sure what type of material to use under it but I would think that a nice piece of slate would probably do the trick and if its sized right would look pretty good.
    Good luck.
