JorgeP
- Aug 28, 2001
Hi, I've just started building my "home-theater" by buying a Barco Graphics 800 projector, second hand. I did all the installation adjustements shown in the manual, so all the test secreens worked properly. But I can not get any external signal. I've connected a video to the video-in port, and an iMac to the RGB (VGA to RGB cable), but the machine shows "no external source connected". If I select manually the address of each port on the control, it looks for it an after a while says " no signal, check imput connections".
Any clue?
Thanx
Any clue?
Thanx
