Banana VS Spade
Discussion in 'Speakers & Subwoofers' started by mark-h, Jan 23, 2004.
  1. mark-h
    mark-h Extra
    Dec 28, 2003
    17
    Any information on the connection properties of these two. Does the spade have more physical contact area than the banana? Looks that way to me.
    But then again, banana sure look kewl...
    Mark
  2. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    I believe you are correct. I think the spades make more contact, but I doubt if there would be any audible difference. Just my .02 [​IMG]
  3. Justin^E
    Justin^E Auditioning
    Jan 21, 2004
    2
    Spade has more contact area, but I highly doubt you will hear the difference when compared to the banana. If you are hooking/un-hooking your wires on a frequent basis then banana is the way to go IMO. Otherwise I would go spade as they are much harder to get pulled out by accident.
  4. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    I use what's the easiest, banana plugs. I've got quite a few of them since building a basement HT room. Everything plugs into five way binding posts on the walls.
  5. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    It would seem that you get more surface area with a spade, but in fact, the difference is likely insignificant. I prefer bananas.
  6. Andy Goldstein
    Andy Goldstein Stunt Coordinator
    May 6, 2003
    214
    i use gold-plated locking banana plugs from ratshack.
    ag.
  7. Mike_Skeway
    Mike_Skeway Second Unit
    Jan 13, 2004
    265
    I use spades, but I don't think there is an audible difference. Bananas are easier though.
  8. Johnny Ayala
    Johnny Ayala Stunt Coordinator
    Nov 13, 2003
    183
    It won't make a difference. All depends on your personal tastes. [​IMG][​IMG]
  9. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    I guess I don't understand why the higher surface area of a spade *wouldn't* matter?
    The resistance of a length of wire is definitely related to cross-section area. That's why lower gauge wire is thicker/fatter/wider/however you want to characterize it. So it seems to me that increased contact area gives you lower resistance which, while not *improving* the sound quality, certainly isn't going to hurt it either.
    Yes, I do have spades, mostly because I think that cheap spades are better than cheap bananas. [​IMG]
  10. DavidLW
    DavidLW Stunt Coordinator
    Nov 21, 2003
    161
    It may not matter whether you use spades or bananas when everything is new but after a few years, the spades connection will not suffer as much as bananas from oxidation. When I remove my spades from the post after being connected for more than a year, I can still see a bright shiny center on both side of the spade where the post was making contact. However, I have seen bananas come out more or less completely dull from oxidation after the same amount of time.
