Banana plugs, speaker pins compatibility
Discussion in 'Home Theater Projects' started by Ryan Leemhuis, Mar 1, 2005.
  1. Ryan Leemhuis
    Ryan Leemhuis Second Unit
    Oct 1, 2002
    490
    I was just looking at the backs of the 2105 and the 2805(Denon) and I noticed a difference in the binding posts. Would it be right to say that the 2105 needs either bare wire or spades? I am not familiar with these types of connections as my current receiver has spring clamps
  2. Ryan Leemhuis
    Oct 1, 2002
    490
    No one? I thought this would be an easy answer
  3. jason_l_h
    jason_l_h Agent
    Feb 27, 2005
    32
    They are 5-way binding posts and can accept bare wire (I don't recommend that), spade, angle connector, or banana plug (my personal choice).
  4. Ryan Leemhuis
    Oct 1, 2002
    490
    thanks so both the 2105 and 2805 can handle bana plugs....how exactly do they go in....from what I see there is not much is any hole for them on the 2105
  5. jason_l_h
    jason_l_h Agent
    Feb 27, 2005
    32
    Just tighten the post and insert the banana plug in the center hole.
  6. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Banana plugs and binding post are all standard. They may look slightly different or one may be a 5-way while the other is not, but bananas should fit exactly the same in both.
    If there is no hole visible there may be plastic inserts in there, just pop them out. A few pairs of speakers and my integrated amp came like that.
