Don
- Jun 30, 1997
information pertaining to how much insulation do i cut off to put into the plug or should i say how much bare wire will be exposed i have the acoustics-research AVP-307 Banana plugs these also have a set screw in them. now does the set screw go into the insulation itself or the bare wire. Don,
