banana plugs for in-wall connections?
Discussion in 'Home Theater Projects' started by ThomasL, Jan 7, 2004.
  1. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    Hello all,
    I wired my 1st floor for sound a few years ago using in-wall AR 14 gauge 4 conductor speaker cable, "old work" electrical boxes and 5 way binding post face plates. I have 4 rooms with one of those rooms being the main switch point using a Niles speaker switch selector. When I terminated the in-wall connections to the face plates, I just used bare wire and I am wondering whether folks think I should have used banana plugs or something else. I see from the forum that many like banana plugs for convenience at the speaker and the amp/receiver but does anyone have any thoughts for the in-wall connections? Will they help keep the connection from oxidizing or just make sure the stray wire doesn't come loose causing a short?
    thanks for your help,
    --tom
  2. ThomasL
    Mar 13, 2001
    963
    Anyone have any opinions? [​IMG]
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,221
    58
    9,110
    Corpus Christi, TX
    Wayne
    Banana plugs are for convenience, plain and simple – i.e., where you plug in and unplug the speakers a lot.
    Wayne A. Pflughaupt
  4. ThomasL
    Mar 13, 2001
    963
    Thanks Wayne. I ordered a few pair that I will use on the back of my receiver to make life a bit easier I think but I'll definitely leave the in-wall faceplate connections as they are.
    --tom
