AmusingistheDawn
- Nov 2, 2008
- Chris
I recently moved into a new home where I have the ability now to set up a HT deditcated room. I want to put banana plugs on the ends of all my speakers to run them through the wall. What is a good "bang for your buck" banana plug to put on. I also will be running them into binding posts which I already have set-up in the wall. Is this the way to do it, or is there a special banana plug port to use? My speakers only have binding posts on them, so I figured I'd just neaten it up by using banana plugs on all the speaker wire ends and slam them into the binding posts. Is this reasonable?
