Jack Heckler
Grip
- Jan 18, 1999
I recently purchased four AudioQuest CF-G BFA banana plugs to use at the Denon 2805 receiver end of my AQ Bedrock cables on my front bi-wired speakers. There are 2 set screws on each plug that seem to do a good job on securing the cable conductors. However, when I push the plugs into the terminal posts, they do not go all the way in and there is about an 1/8" gap between the end of the post and the barrel of the banana plug. Should I be concerned about this uninsulated 1/8" gap? Should I wrap them together with electrical tape or some other material?
Thanks for your help...Jack
