banana plug question?
Discussion in 'Speakers' started by Jeff smit, Nov 23, 2003.
  1. Jeff smit
    Jeff smit Agent
    Nov 14, 2003
    32
    Never used them befor and when test fitting with my speakers, I noticed that the plug is longer then the hole and when pushed in seem to have a wobble to them. Is that normal?
    thanks Jeff
  2. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    I dont think so. I have used a few different brands of compression fit bananas before in my Paradigms and Polks and they always fit very snug, no movement at all
  3. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    Jeff,
    It's not uncommon for them to be longer than the hole. However, wobble is not good. You can usually take a knife or other pointy object and pry the tangs apart a bit on the solid kind or puff out the blades on the hollow kind.
  4. Jeff smit
    Jeff smit Agent
    Nov 14, 2003
    32
    thanks for the replys I went out today and looked at several different brands and the length varies. I think one of the shorter bananas would work better as it would bottom out so to speak and help hold it.
  5. Robert Cowan
    Robert Cowan Supporting Actor
    Nov 10, 2003
    504
    audioquest makes some that dont have springs or leafs. they are like a rolled tube of metal that slides in. they hold VERY tight.
