Daman
- Feb 4, 2004
Hi Guys,
Purchased Banana connectors for my speakers yesterday from Radioshack, and though this may sound stupid i wanted to ask whats the best way to connect these to the normal monster speaker wire.. the pin is simple type gold plated one which is cut in half at the end.. probably to crimp it on the wire.. do i need to solder it or just fitting the wire tightly will do,how much speaker wire needs to be exposed to the pin.. at present theres a small bit just at the end of it.. thanks for your replies in advance
Daman
Daman
