"Baltic Birch" Plywood
Discussion in 'Home Theater Projects' started by Joseph Sabato, Dec 18, 2003.
  1. Joseph Sabato
    Joseph Sabato Stunt Coordinator
    Sep 13, 2003
    67
    I went to Home Depot today to see if I could find some "Baltic Birch" plywood and I did not see anything that had that name, nor did the guy that worked there know anything about it.
    They did have 2 X 4 sheets of Birch plywood (~16.00 / sheet) that is intended for "architectural applications". Looking at all 4 cut edges, there were no apparent voids like I saw occasionally on the other plywood that they had....is this the right stuff?
    If I build an IB manifold, I want to use plywood since the box will be cantilevered from wall studs and 2 Tempests are not exactly light. MDF will not cut it in this application.
    I have not tried the custom woodworking shops in the area to find out where to get it. Buying it at HD would just be easier, and maybe cheaper. Thanks.
  2. Allen Ross
    Allen Ross Supporting Actor
    Sep 30, 2002
    819
    Try an actual hard wood yard, I only buy MDF from HD, everything else i try and go through a local yard, most to the times the wood is better quality, and i am supporting my local business. Also if you are looking most the times if you aren't picky on size they will cut you a deal with scraps that they can't really sell.
    I looked for BB 13 ply at 5 different local yards before i found on that had it. and it was worth it.
    a 5x5 sheet of BB ran me 55 bucks, i got my two enclosures out of one sheet so i was happy. In all honesty i don't think BB is going to save a lot of weight, one of my Pis tips the scales at over 25 pounds.
  3. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    BB is quite common and normally stocked at distributors, so either have them check their supplier or get their number/location and check with them. Even if they don't have it they'll probably know if anyone else does.
    Could be. Count the plys, if 13 for 19mm (3/4").......
    Agreed.
    >In all honesty i don't think BB is going to save a lot of weight.....
    FWIW, BB is listed as 41 lbs/ft^3 Vs MDF's 50 lbs/ft^3.
    GM
  4. Pete Mazz
    Pete Mazz Supporting Actor
    May 17, 2000
    761
    I don't think BB is really necessary for IBs. I would, instead, just double up the birch ply you saw at HD and use it.
    Pete
  5. Joseph Sabato
    Sep 13, 2003
    67
    Thanks guys,
    First I will go count the plys on the material at HD, Then I will call around to some of the local yards or the local custom woodworking place down the road.
  6. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    I used the BB from HD in 2x4 sheets for my last sub. It is indeed 13 plys for the 3/4" material. No voids, very nice.
  7. Jeff Hoak
    Jeff Hoak Stunt Coordinator
    Jun 26, 2001
    137
    For an IB there's not even any reason to use "birch" plywood. The birch layer is nothing more than a veneer and there for looks only.
    Since an IB is usually in an attic or basement and not really "visable" why not use a decent grade of plain old plywood?
  8. Ken Cline
    Ken Cline Stunt Coordinator
    Jun 30, 1997
    99
    Not true BB plywood. BB is not veneer, each layer is birch. This is the same stuff found on quality kitchen cabinets(drawers). Great stuff to work with and much less dust than MDF.
    I have a building surplus in my area and they have 19mm 5x5 for $25. This is where I usually get mine.
  9. Chris Keen
    Chris Keen Stunt Coordinator
    Aug 14, 2002
    117
    Dang! That is super cheap for BB ply. Yeah, the other thing to note, is that this stuff almost always comes in 5'x5' sheets. Not that it can't come in other dimensions, but I've just never seen it come in anything else. Good stuff though.
  10. Allen Ross
    Sep 30, 2002
    819
    they also alternate the grain by 90 degrees each layer to add rigidity, I also have to say that i think BB is much much stronger then MDF.
    If only i could fine a 5X5 sheet for 19 bucks [​IMG]
  11. Alex-F-V
    Alex-F-V Stunt Coordinator
    Jul 22, 2003
    81
    For that cheap it would almost be cheaper for you to buy me some and have it shipped to me!!
    Very lucky... my local yard is about 55-60 bucks for a 5'x5' sheet.
  12. JohnGil
    JohnGil Stunt Coordinator
    May 14, 2003
    65
    HD does carry it, its not with all the other construction ply's its staked with the oak veneer plywood.
    I just bought a sheet of 3/4" for the braces in my North Creek speakers.
  13. Jeff Hoak
    Jun 26, 2001
    137
    The material I was refering to was the HD "birch" plywood. It most definately is NOT baltic birch. I haven't done a "ply" count but I've worked with true baltic birch and this stuff ain't it.
    Granted it's a WORLD better than the B-C Exterior grade stuff but under the birch is still good old yellow pine.
    I guess we just get the crap here in Florida. I've been to every Home Depot, Lowes, and locally owned lumber yard within a 3 hour drive from my house and I've yet to see true baltic birch here.
    I still keep looking though...
  14. JohnGil
    May 14, 2003
    65
    Yeah maybe it is a Florida thing, because the stuff here in seattle is the real thing. Its about $54 a sheet.
  15. Al Garay
    Al Garay Stunt Coordinator
    Oct 23, 2002
    82
    John,
    Which Home Depot in Seattle? Did you see Baltic Birch plywood in 4'x8' sheet?
    I bought a 5'x5' sheet at BlackStock Lumber for about $35.
    Al
  16. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    These guys have offices in Orlando and Tampa and sell 5 x 5 sheets of Baltic Birch Plywood at wholesale - give them a call and see where you can get their products retail:
    http://www.dixieply.com/orlando.htm#about
  17. George W
    George W Stunt Coordinator
    May 25, 2001
    91
    Hey John,
    You're not the only one building North Creek's in Seattle. I just picked up some baltic birch yesterday from Dunn Lumber for $45. Did you get yours from the Depot on Aurora? I now need to find some sort of cabinet maker around here who I can get to cut the wood for me; I'm sick of my Dad's table saw which seems incapable of producing square cuts, leaving me with many hours of filling and sanding. By the way, which kit are you building?
    George
  18. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Some folks might be confusing true Baltic Birch solid core plywood with the much more common (and stocked at the big "home" stores) Birch-faced pine plywood. That's the plywood that most kitchen cabinets are made from and yes, the Birch is only a veneer on the faces of the plywood. I don't think HD carries true BB plywood.
  19. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    I see a lot of these "where to buy baltic birch plywood" posts here. Maybe we should create a thread on it, and can have everyone post where they get it. Could be sorted by city, state, zip code or something.
