Bad Image From N64 on LCD Projector
Discussion in 'Gaming' started by Brian Dobbs, Jul 1, 2003.
  1. Brian Dobbs
    Brian Dobbs Ambassador
    Jul 1, 2001
    1,026
    163
    1,610
    Maryland
    Brian Dobbs
    I just plugged in my N64 to my LCD projector (resolution = 964 x 544) and the image doesn't look good at all. Is this because of the lower quality of the graphics? What's the best way to hook up a gaming system to a projector? Please share your stories and setups.
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    Yup, N64 is pretty low res. That's why the games looked like they had vaseline smeared ont he screen because of all the anti-aliasing
  3. Ryan FB
    Ryan FB Second Unit
    Oct 4, 2002
    277
    The N64 will always look somewhat blurry due to the anti-aliasing, as Jeff said. However, the best image for a projector would probably be attained by using a good S-Video cable (these can be had about anywhere, and the Gamecube and N64 video connectors are the exact same so you can use a cable labeled for either) and feeding it into a scaler/deinterlacer.
  4. Michael St. Clair
    May 3, 1999
    6,001
    N64 runs most games at around 320x240 (PSX is the same). A typical data projector has below-average line-doubling (not really deinterlacing because we aren't talking about film here). Combine the resolution with the doubling and the scaling, and it's not going to look so hot.
  5. Brian Dobbs
    Jul 1, 2001
    1,026
    163
    1,610
    Maryland
    Brian Dobbs
  6. Ryan FB
    Ryan FB Second Unit
    Oct 4, 2002
    277
  7. Brian Dobbs
    Jul 1, 2001
    1,026
    163
    1,610
    Maryland
    Brian Dobbs
    I do have Turok 2. So that's why it looks so much sharper? because you can run it at twice the resolution? interesting.
  8. Jeff Kleist
    Dec 4, 1999
    11,267
    Games that use the RAM addon like the aforementioned can run at higher res
  9. Mark Hedges
    Mark Hedges Second Unit
    Mar 21, 2003
    442
    Most of the games released in the last year or so of the N64's life supported the expansion pak and a few required it, such as Donkey Kong 64 and Zelda, Majora's Mask.
