Dave Miller
- May 9, 1999
Ok, here's the deal. I went by Home Depot and picked up two 18" florescent fixtures and a GE Sunshine bulb rated at 5000K. That's the highest they carried. One fixture is just a regular white "under the cabinet" type for your kitchen. The other is a "black-light" fixture. Both work (in theory) with the bulb I bought. I'll know for sure when I get home.
On the regular fixture there is a white curved area behind where the bulb will sit. On the "black-light" fixture, there is a mirrored curved area behind where the bulb will sit. I bought both b/c I'd prefer the black one since it would hide better w/ my RPTV and look nicer, but I'm unsure if it will work.
So my questions are as follows:
1. Should I notice any difference in the two fixtures using the Sunshine bulb? (ie. will the mirrored surface affect it?)
2. Is it correct to assume that the mechanics and "guts" of a florescent "black-light" fixture would be similar, if not identical, to the regular florescent fixture?
3. Where should I put the fixture and where should it point? I've got a Tosh 65H80 and plenty of room behind the center channel. I bought two "L" brackets to make a shelf for the fixture if the bulb needs to be flush with the top of the TV, or lower than the top of the TV.
4. If I use the "L" brackets, would #6 1/2" wood screws or #6 3/4" wood screws penetrate the cabinet? I obviously don't want to do that, but I'm not sure how thick the Tosh cabinet is.
5. If I put the light behind the center channel, will it cause interference? Everything is hooked up to a Monster Power Center HST2000, but the light probably wont be. Is that good or bad?
Oh yeah, the wall behind my TV is medium oak wood paneling, not too dark.
Any input would be appreciated?
Peace,
DM
PS - I tried to do a search, but it wasn't working.
"We all end up dead, the question is how and why."
[Edited last by Dave Miller on July 24, 2001 at 05:57 PM]
Peace,
DM
