Backing up VHS to Panasonic E50 and then editing on a PC?
Discussion in 'Playback Devices' started by Chris S, Feb 16, 2004.
  1. Chris S
    Chris S Cinematographer
    Apr 9, 2000
    2,539
    9
    110
    Chris S
    I'm not really sure which forum this best fits into so please excuse me if I'm in the wrong one.
    I am wanting to start archiving my VHS home movies but I'm not really ready to buy a whole new computer and all the equipment needed to capture them to a PC. I have a funding and wife issue (i.e. she says we don't have the money). So what I am thinking about doing to buying a DVD recorder, maybe the Panny E50, and using that to burn them to disk. Then sometime later on down the road, lord knows when, I will go back and do some editing on them via a PC and re-burn the discs.
    Is that doable? Can I strip the video from the burned DVD-R onto my computer, edit it, and then re-burn a new disks? Should I be concerned over quality? Is a set top DVD recorder just as good (audio/video) as a PC? Are there inexpensive PC alternatives that I should examine? My understangin is that I would need an 80gig HD, AVDV 100, NED 2500UA DVDRW, and at least a 1.7 GHZ PC.
    Chris S.
  2. Scott Merryfield
    Dec 16, 1998
    12,730
    1,333
    9,110
    If you just want perform simple editing, such as removing some of the footage, you may want to consider a model with a built-in hard drive. Panasonic's current models with such a feature are the E80 and E100. The E80 is basically the same recorder as the E50 you are considering, but with a built-in hard drive.
    With the E80/E100, you can copy your home video footage to the hard drive, edit the footage, and then burn a bit-for-bit copy to DVD-R.
    If you want more advanced editing options, such as fancy menus, inserting fades and other scene translation techniques, then a PC is your only option currently.
  3. Chris S
    Apr 9, 2000
    2,539
    9
    110
    Chris S
    If I use the E80 for now can I later pull the audio and video off of the DVD-R for more editing on the PC? Or would I need to recapture it?
    Chris S.
