Background Noise effect on SPL readings
Discussion in 'Archived Threads 2001-2004' started by Jin E, Aug 23, 2002.
  1. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
    I'm in need of some technical info... or possibly some pointers on where to go to find some information. Is there some way I can calculate how much background noise will effect the reading I get from my SPL meter? i.e. if the background noise was 55dbl... and I measure the acoustic output from a fan as 70.6 dbl, what would be the effect of the reading if the background noise was 60dbl? 65dbl?
  2. Rick Guynn
    Rick Guynn Second Unit
    Mar 23, 1999
    473
  3. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
    Thanks! Just what I was looking for!
