Back Wall Speakers - Wall Mounted or on a Stand
Discussion in 'Archived Threads 2001-2004' started by armin, Mar 14, 2002.
  1. armin
    armin Extra
    Jan 29, 2002
    16
    Hi Everyone,
    Is there any difference in mounting my back wall speakers(7.1 setup) using a wall mount that allows swiveling of the speaker(up and down/ left and right) or just mounting the speakers flush against the wall(no movement) ???
    Should the speakers touch the wall(flush mount) or should it be away from the wall(spkr wall mount)
    thanks in advance
    armin
  2. Paul_Dunlop
    Paul_Dunlop Second Unit
    Nov 28, 2001
    318
    Hi
    2 issues -
    1. with swivel mounts, you will be able to adjust their position if you need/want to improve the sound
    2. if they are rear ported, you don't want them right against the wall - they need room to allow the air out of the port - if they are front ported, this would be OK
    Hope this helps
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I have all my speakers, with the exception of my center, on identical stands, all set at least 1 foot from the wall.
