Back surround: Direct radiator or Dipole/Bipole?
Discussion in 'Archived Threads 2001-2004' started by DEAN DE FURIA, Oct 3, 2001.
  1. DEAN DE FURIA
    DEAN DE FURIA Stunt Coordinator
    Feb 11, 1999
    78
    I'm setting up my first EX/ES system. What's the best for back surround? I'm using dipoles for the sides.
  2. derek
    derek Second Unit
    Dec 20, 1998
    494
    I would match your surrounds. If you are just using a single speaker...get a dipolar as it will broaden the rear soundstage. If you plan on using two back surrounds...direct radiators should work comparably well as dipolars. But again try to match your side surrounds (manufacturer etc.)
    Derek
    Surround EX FAQ: http://www.geocities.com/Heartland/P...urroundex.html
