B & W subs
Discussion in 'Archived Threads 2001-2004' started by Brad Newton, Jan 29, 2003.
  1. Brad Newton
    Brad Newton Second Unit
    Aug 14, 2001
    382
    do you recommend them????? I will be using B & W 603's with either Pioneer 45 or Sony 4ES, mostly for home theater. My room is 25' x 15'.
  2. John Spicer
    John Spicer Agent
    Dec 16, 2002
    46
    I cant say that I have heard them but I matched my 603's with a SVS sub and have not looked back [​IMG]
    -- John
  3. Ned
    Ned Supporting Actor
    Feb 20, 2000
    838
    B+W subs are overpriced and underperforming. Look elsewhere.
  4. jeff_coil
    jeff_coil Stunt Coordinator
    Dec 3, 2002
    157
    Ditto John
    CDM's & SVS 20-39pc+ equals [​IMG]
  5. Ted_Wern
    Ted_Wern Agent
    Dec 27, 2002
    38
    Once again I totally disagree......After auditioning the SVS and the Hsu.....I still went with the B&W ASW600. I know that is the sub of preference here but like all speakers it is a matter of preference. Listen to a few before you take the plunge. Advice is great, but your ears are the best decision maker...
  6. Willem Vos
    Willem Vos Stunt Coordinator
    Nov 14, 2000
    227
    B&W makes great products, still, having said that, take into account that all B&W's new subs are the relatively small sealed types.
    This type of sub is not able to attain real low frequencies without compensating for its defficencies with lots of amp power. The ones that have this are therefore very expensive.
  7. Tim Morton
    Tim Morton Stunt Coordinator
    May 5, 2000
    212
    My brother has the B&W set-up you are refering too, and it sounds pretty decent. I don't know how much it costs, but subwoofer wise it produces a softish thump, and it blends well with the speakers. I cannot say how it compares to the SVS, but i would think the B&W sub sounds like a good buy at around $300 bucks....if it where to cost you more I think i would listen to the SVS or HsU and make a choice from there.
  8. Brad Newton
    Aug 14, 2001
    382
    That's the problem........the only subs locally that I can audition are Klipsch, Paragigm, Def Tech, & Velodyne + B & W.
  9. Steve_Ma
    Steve_Ma Second Unit
    May 7, 2001
    420
    I have an ASW1000 matched with 603 mains. My ASW performs very well and more than meets the demands of my room and listening preferences...
    That being said, I got a crazy good deal on that sub. If I were paying retail, I probably would have gone with a SVS or HSU.
    --Steve
  10. Liam Shan
    Liam Shan Extra
    Jul 19, 2002
    17
    I have the baby B&W ASW300 sub matched with 602s3 mains and have been very happy. It is quite amazing for a sub of it's size. I needed a relatively small sub and found the little b&w to give me the best result from my test selection. Great musically and performs well in HT down to quite low frequencies (quoted to be 27 - 150 Hz -3dB). I haven't heard SVS or HSU so these my be better, but I can say that I'm very happy with the sound and build quality from my little B&W.
  11. Lam Nguyen
    Lam Nguyen Stunt Coordinator
    Nov 29, 2002
    108
    I have the asw 650 paired with 7nt, Willem hit the nail on the head. The new B&W subs are seal enclosure, and have problems going to real low frequencies. On a couple of scenes from MI 2 my 650 let out some weird noises. On the other hand I think B&W sub does a great job at music because its punchy, on movies it shakes my couch. My living room is about as same as yours, and my B&W does a fine job.
    It does have problems with very low frequencies but thats something I can live with. My reason for buying my 650 was that I wanted to match with all my other B&W speakers and that it was better and cheaper than some of the M&K that I compared it with. Just my 2¢.
