B & W not deep enough
Discussion in 'Archived Threads 2001-2004' started by NatL, Jan 25, 2003.
  1. NatL
    NatL Stunt Coordinator
    Sep 18, 2002
    72
    I have recently embarked into the world of 16:9 RPTV with a Pioneer SD-583HD5. I have really appreciated the quality of DVD's on it, overall, particularly 16:9 enhanced ones.
    My big problem, however, is the quality of Black & White picture. I have been watching my copy of "The Third Man," which on my old Sony trinitron looked amazing - very deep blacks. The city of Vienna really came alive. I could see the rain glisten on the streets.
    My DVD player is merely an old Sony S500D (I was an early adopter) and I have not had ISF calibration - although I have calibrated according to some material I read on-line(which worked wonders - my B&W movies aren't bathed in a sepia tint anymore).
    On my RPTV, the blacks just aren't very deep at all. The rain doesn't glisten. The picture doesn't leep out at me at all.
    Does anyone else have this problem? What are the best settings to monkey with to sharpen that up? Could it be my DVD player? Can one never really expect that deep of blacks on an RPTV?
    N
  2. NatL
    Sep 18, 2002
    72
    I thought I'd pull this thread back up again, one more time, because it is really important to me.
    Any thoughts?
    N
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Professional calibration ... AVIA or VE?
    Regards
  4. NatL
    Sep 18, 2002
    72
    I have VE.
  5. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Have you done the other requisite tweaks like E-focus and M-focus?
    REgards
  6. NatL
    Sep 18, 2002
    72
    I'm not sure what you mean?
  7. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    electronic focus
    mechanical focus
  8. NatL
    Sep 18, 2002
    72
    I haven't done those. Are they in the service menu? I was a little nervous going in there, and essentially only made the adjustments from:
    http://home.attbi.com/~jack.lew/sd582.htm
    Then I dropped my brightness by about 10 and it was good.
    N
  9. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    These are physical tweaks ... time to get down and dirty.
    Regards
  10. NatL
    Sep 18, 2002
    72
    Do you really think these are things that I will need to do? Are they hard for a non-pro to do? Will they help deepen the blacks on B&W sources?
    N
  11. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    They can't hurt, but if you really want better blacks ... then it is time to consider paying the piper by bringing in the heavy testing equipment.
    REgards
  12. NatL
    Sep 18, 2002
    72
    Heavy testing equipment - as in getting an ISF technician?
    Are there any more practical settings I could look for? What are the key things for deeper blacks?
    N
  13. MichaelFusick
    MichaelFusick Second Unit
    Aug 14, 2002
    301
    Key things would be proper contrast and brightness settings #1.
  14. Mark Zimmer
    Mark Zimmer Producer
    Jun 30, 1997
    4,300
    40
    Get the ISF calibration. While it made a difference in a number of respects, setting the greyscale properly on my set made a HUGE, HUGE difference in black & white movies. Chances of having a proper greyscale out of the box are approximately zero. Since you don't sound comfortable doing the tweaks, it's probably for the best to have a professional do them. I was in the exact same boat.
  15. NatL
    Sep 18, 2002
    72
    How much do ISF calibrations go for, generally? Assuming there is someone nearby...
    N
  16. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Basic grayscale calibration of an RPTV has a recommended price of $275. (two hours or so ... never more)
    Advance calibration can cost from about $400 to $600 or more depending on the permutations of serice you want.
    (4 to 6 hours typical)
    Regards
