David_Way
- Aug 6, 2001
Current set up is B&K Ref. 30, with dm602s2 as fronts and surrounds, lcr6 as the center, and a pair of svs 16-46's for the subs.
Looking to upgrade and am pretty sure that im going to get the cdm1nt for the rears (and maybe for the side surrounds for 7.1, budget allowing), the cdmcnt for the center, but I cant decide what to do about the fronts. Im waffling on the cdm line, between the 1nt's, the 7nt's, and the 9nt's. Part of this is that after reading threads about bass management, ive pretty much come to the conclusion that setting all speakers to the "thx small" setting on the 30 is the way to go. So if I do that, is it overkill to get either the 7's or the 9's, as most of the bass is routed to the subs anyway? Primarily this is for HT, but I do listen to the occasional cd here and there. And there is a pretty large price difference between them as well.
Any thoughts?
Thanks for the input.
Any thoughts?
