B&W dm602 s3 or Klipsch RB3's ?
Discussion in 'Archived Threads 2001-2004' started by JauCheeze, Nov 5, 2002.
  1. JauCheeze
    JauCheeze Stunt Coordinator
    Sep 24, 2002
    87
    Lookin to get some bookshelfs... title says it all.
    I've heard the B&W's and was pretty happy w/ the sound. But I've also heard good things about the Klipsch's. These will be used as mains in my home theater setup, with a onkyo sr600 receiver. They're both around the same price range, the klipsch being about 50 bucks more. So which ones should i get? Are there any other speakers i should listen to?
    thanks
  2. Kevin McCurdy
    Kevin McCurdy Stunt Coordinator
    Oct 13, 2000
    183
    Is it possible for you to demo both in your system? I know some dealers have a return policy which would allow you to return them within a certain time frame. Check with your local dealer and see if this is possible, if so try them both side by side in your system and choose the pair you like the best.
  3. JauCheeze
    Sep 24, 2002
    87
    it would be hard for me to audition both of them because of the limited number of b&w dealers in my area. Klipsch would be no prob, because goodguys carry them.
