B&w Cdm Cnt (1 Viewer)
James_N_H
I have been considering upgrading my LCR60-3 centre to the CDM NT, firstly if anyone has any experience would this be a good idea as the rest of my speakers are also from the DM range? Also I am slightly concerned that the CDM NT range may be due for replacement as its been out for around 2years now, or is it the DM range that B&W only tends to replace reasonably often?
rodneyH
The CDM line does seem to get updated less than the 600 line. I have the CDMcNT and ran it with my 602s then I loved it so much I upgraded to the CDM7NT mains
James_N_H
I wont be upgrading my mains to the CDM range as I auditioned both the 7NT and 9NT and wasnt overly impressed with either, I will be sticking with my DM605 S2's for aslong as possible, or until I can afford something from the Nautilus range, which being a studend wont be for a good few years yet. I will try and get a demonstration of a CDM CNT to compare and see if it will make the difference.
Thanks for your reply.
James_N_H
The link you gave is quite handy however the person in question is comparing the LCR-600 where I am comparing the LCR-60, the main difference being the cost between the two and the fact that an upgrade for me from the LCR-60 is a much bigger step. I am debating however as to whether I should wait a while and get the HTM-2, although would this be a very bad match for my main speakers?
maxwell_otto
