B&W CDM-7 HTM-2 CDM-1 questions (1 Viewer)
Mike Bassi
Mike Bassi
I just got a real good deal on these speakers. I also just bought the 10 inch B&W sub, the ASW 675. I'm going to pair this off on a B&K 505 reciever. I want to know what the general impression everyone might have with this set up. The center channel is a HTM-2 Nautilus center channel. I was curious if anyone might give me some tips on such a system, and reviews.
Thanks in advance all
Cheers
Mike
I have the Rotel RSP-1066/RMB 1095 combo driving CDM 9NTs /Nautilus HTM 2. The sub I am using is a Paradigm Servo-15. I think the combo is awesome for HT I do not use it for SACD at all.
Kris
Mike Bassi
Mike Bassi
I'm hoping it's good for not only HT but being very musical as well.. Thanks for your input :)
Cheers
Mike
Mark C.
Mike:
You should be very happy with your setup. The B&K should mate nicely with the B&Ws (lots of Bs). Did you get the CDM NTs or the original CDMs? The Nautilus center is excellent. I have the CDMSEs across the front of my HT and am constantly amazed. I'm using B&W 601S2s for my rears. I've had this speaker setup for more than three years and haven't had the urge to upgrade, although Nautilus across the front would be nice!
Happy listening.
Mark
Mike Butny
I used to have the cdn1t for my fronts along with the htm2 center and the sound was very impressive. I just recently upgraded the cdn1t to N805's and cant tell how awesome they sound. Watching movies and listening to music is truely magic with this setup.If you can afford to upgrade to the N805 please do it. Having three identical speakers in the front will make a huge difference and put a smile on your face with every listen.
Arron H
I think you are going to like your new speakers. I have the HTM2 and really love it. Definately worth the extra $$ IMO. I have 805s up front and 601s in back. I love this system.
BJK University
