B&K ST-140 or ST55.2?
Discussion in 'AV Receivers' started by Bob_S, Jul 31, 2004.
  1. Bob_S
    Bob_S Stunt Coordinator
    Sep 13, 2003
    87
    I need help deciding between the two. The ST-140 is used but in good shape, its a 105wpc, the other is new and only 55wpc. I can't decide they're both the same price and I cant find any reviews on the st55.2. Any of you guys know?
  2. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    More power is always better IMO, id go with the ST-140 if its been taken care of.
  3. Bob_S
    Sep 13, 2003
    87
    I was thinking the same except, I'm going to running an Adire KIT51 and I'm not sure but can the adire's handle the power of ther st-140? its close to 200wrms, while the 55.2 is 85
  4. Nigel Hooper
    Nigel Hooper Stunt Coordinator
    Jul 1, 2004
    208
    The ST140 is one of the great power amps of all time.
  5. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    An all time classic, I agree. I have seen them go as low as $180 on A'gon.
  6. gene thomas
    gene thomas Auditioning
    Dec 21, 2003
    12
    I agree that the 140 is a great amp. I have had one for several years and recently passed it to my brother to use till he can buy his own. You won't go wrong. Amps are a bit like engines, there are no substitutes for Cubic Inches!!
    Gene Thomas
