B&K Reference 200.7 problem
Discussion in 'Archived Threads 2001-2004' started by John H, Jan 23, 2003.
  1. John H
    John H Second Unit
    Nov 27, 1998
    472
    I just installed a Reference 200.1 in my system. I cycled through the processors speaker setup test tones to confirm everything was working.
    The amps channels 6 and 7 have extremely weak unusable output. I am using these channels of amplification to drive my left side and left rear speakers.
    I have traced the problem to the amplifier itself. I have eliminated "all" other possibilities.
    In the manual under troubleshooting...
    Problem Channel sounds distorted and low output
    Possible Cause Blown rail fuse
    I am not sure about the distortion part as I have not tried playing any program material with the amp, just pink noise and the output is just above audible from these 2 channels and measures 75db from the others.
    Would a blown rail fuse only affect 2 channels?
    I am going to contact B&K in the morning before requesting a replacement from my dealer which is an hour drive. And unfortunately this is the last unit that was in stock.
  2. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
  3. John H
    John H Second Unit
    Nov 27, 1998
    472
    Problem rectified.
    The input connection method unbalanced/balanced button was depressed to the balanced position that controls those 2 channels. I am using the unbalanced input connections. There is one selection button for each pair of channels.
    It obviously was accidentally pushed in during cable connections. I can't beleive I missed that during troubleshooting. Lack of sleep I guess!
  4. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    I have done that with my Proceed Amp2 and believe it or not its a common mistake, so dont blame sleep for that.
    BTW I just saw your HT system. Looks way cool. I just had one question - why are you replacing the Parasound with B&K. Any particular reason related to sound or you just wanted a one box amplifier for all your seven channels?
  5. John H
    John H Second Unit
    Nov 27, 1998
    472
  6. Albert Damico
    Albert Damico Stunt Coordinator
    Jul 8, 2002
    118
    One important question: Where did you get the sign that says "This Home Theater Powered by Dolby Digital"
