B&K Ref Component Inputs
Discussion in 'Archived Threads 2001-2004' started by Ron Alcasid, Feb 15, 2002.
  1. Ron Alcasid
    Ron Alcasid Stunt Coordinator
    Apr 11, 2000
    168
    Do the component video inputs on the Ref 30 have enough bandwidth for HDTV? Their spec sheet says 10 to 20 MHz, which doesn't seem to very good. I don't know if that just applies to composite and s-video.
  2. Jerry Klawiter
    Jerry Klawiter Screenwriter
    Dec 3, 2000
    1,412
    For true HDTV you will need 300 to 500 MHz.
    This is why the best switches are rated as they are.
    You need 3-5x required bandwidth for no loss.
    That's why the new Cinepro is at 500MHz.
    Not much more support for these speeds yet.
    It's best if you can just wire direct to the display
    and forget the switching offered in a pre-pro.
  3. Gifford L
    Gifford L Agent
    Jul 11, 2001
    41
    The specs are for S and composite video. The component switching is mechanical via relay and has a much higher bandwidth. B&K says at least 100Mhz I believe which is all you need for HDTV most people say since the bandwidth of HDTV is in the 30Mhz range.
