B&K Ref 30??
Discussion in 'AV Receivers' started by Carl Gaff, Mar 9, 2004.
  1. Carl Gaff
    Carl Gaff Second Unit
    Jan 26, 2002
    281
    Okay B&K owners, I need your help. I am currently using a Sherwood Newcastle 9080R as my home theater preamp. I have a chance to purchase a B&K Ref preamp that was a demo for a short period of time for $850-$950. I have checked and can get the Ref 30 upgraded to all current surround modes through B&K for $498, making my cash out-put somewhere between $1348 and $1448. My dilemma is this:
    1. Is the Ref 30 worth the price I've been offered?
    OR
    2. Should I bypass the Ref 30 and wait for the new Sherwood-Newcastle preamp to come out?
    Any CONSTRUCTIVE comments or advice will be greatly appriciated
  2. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    I'm not an owner but I have seen the ref 50 for about$1600.00,is it worth a few hun more,prolly.
  3. DavidK
    DavidK Extra
    Aug 10, 2000
    23
    Carl Gaff,
    The upgraded REF30 would indeed be a great product..but like CurtisC said, you should/could look around for a similar good price on a new/used REF50. Then based upon the dif in price, make your decison one way or the other.
    By the way, I recently had my B&K 305 upgraded to 315 and I had no major problems and I felt it was well worth it.
    Good luck...
  4. Carl Gaff
    Jan 26, 2002
    281
    Thanks for the idea Curtis. David, do you happen to know what the main differences are between the Ref 50 and the Ref 30? Thanks.
    Carl
  5. Stephen M
    Stephen M Stunt Coordinator
    Sep 16, 2000
    169
    No difference except for balanced outputs on the Ref 50 and THX Ultra processing, I think.
  6. Chris Copter
    Chris Copter Auditioning
    Dec 17, 2003
    7
    I think that you also get upgraded dac's and also PLII and NEO 6, I don't think these were on the ref 30. It also has a notch filter on the 50, that may not be on the 30 either.
  7. DavidK
    DavidK Extra
    Aug 10, 2000
    23
    Carl,
    The two posts above pretty much cover the main differences...there might be a few more differeces. Just go to B&K site &/or call B&K and they should be able to provide you with all of the differences.
  8. Carl Gaff
    Jan 26, 2002
    281
    Thanks to all for their advice and info
  9. Dan Driscoll
    Dan Driscoll Supporting Actor
    Aug 1, 2000
    937
    2
    FYI, the Sherwood-Newcastle P-965 is now available. List is $1499, IIRC.
  10. Chris White
    Chris White Second Unit
    Feb 12, 1999
    391
    Just to clarify, here is what is included in the $499 upgrade of a Ref 30 to a Ref 31:
    • New Motorola (56367-DSP) processor
    • New 24/192 DACs
    • New formats: DPLII, THX Ultra2, DTS-ES, NEO:6
    • New system boards/cards
    • New blue display
    • New user's manual
    After the upgrade, the Ref 31 becomes essentially a Ref 50, except a Ref 50 has balanced outputs and an additional component input.
  11. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I guess if you can get the Ref 50 for $1,500 used/new it would be a better buy than the $1,000 price tag on a used B&K30....am I correct?
  12. Chris White
    Feb 12, 1999
    391
    Assuming they're in equivalent condition, yes, a used Ref 50 at $1500 would be better than a used Ref 30 ($1000) upgraded to a Ref 31 ($499) because you would have the balanced outputs and the additional component input. Plus, as a newer model, it will probably hold its market value better.
  13. anth_c
    anth_c Stunt Coordinator
    Jul 17, 2002
    79
    The other benefit of the Ref. 50 is the remote control. It is an OEM model of the hometheater master.
