B&K Ref.30 & SACD Multichannel?
Discussion in 'Archived Threads 2001-2004' started by john g russell, Feb 13, 2002.
  1. john g russell
    Jan 26, 2002
    21
    Does anyone know if Ref.30 has direct throughput for M/C music. It does for 2 channel. It has 5.1 DVD-A in/outs, but I can't set it for 'direct' on menu etc. Also, is DVD-A an anolog signal or is it converted by processor and then outputted as anolog? I have Sony XA777es M/C SACD.
    Thanks for any help.
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Set the input you want to use for the 5.1 input to "DVD-Audio" and you'll be all set. I think the flag on Input Setup is "DVD-Audio Input" Yes.
  3. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    John's right. It is "DVD Audio Yes".. same as my 307.
  4. John Kotches
    Mar 14, 2000
    2,635
    Keep in mind that DVD-Audio is just a label for the input, and it's perfectly acceptable to use a multi-channel SACD on that input [​IMG]
  5. John Morris
    John Morris Guest
