Rizal Malik
- Mar 25, 2001
This is on the B&K AVP4090 pre/pro.
My friend opened up his pre/pro last week, and changed the capacitors, diodes, bridge rectifier and voltage regulators on the power supply section. However as soon as he recconnected to CDP and amplifier, fired it up, there isn't any sound coming from all the speakers.
We've checked the individual components installed and looked to be OK. Regulators are outputting 5, 15, -15VDC similar to the previous components. Capacitors also have voltage readings across them, which should be OK. All the new components have similar specifications as with the originally installed components.
We did test tones and sources from CD player (digital and analog inputs), but still there isn't any sound from the speakers.
Has something short out? No burn smell so far, and front panel display is normal. We desperately need help to find out whats wrong with this thing. If the components are similar, then everything should be OK, but it isn't.
Thanks in advance for any tips/ help...
Rizal
Rizal
