B&K 507 basic setup question (1 Viewer)
Joe
Currently, the 507 defaults to Prologic w/ 7 speakers for tuner. I want to change the default to something else without using a computer. It appears that I am not saving the config after I change it. Where is the SAVE button or how is this done?
Does anyone have some more extensive information on how to work this thing. The manual is quite limited. It does not even mention how to do FM presets. Seems like there should be a tech document floating around.
Thanks.
Joe
I figured out how to save changes.
I would still like to find some more information on the 507 though.
Jerry Klawiter
Joe,
Have you fired up the software just to take a look?
It will help familiarize you with the menu layer structure.
The software does have a emulation mode, No real connection required.
Just an idea.
Bryce Miner
You need to configure your individual inputs for the default per input. push menu then down to input, cycle through inputs by moving the knob right or left.
Save key is used for setting up presets.
Righ
