Axioms with Denon 1802 or 2802? (1 Viewer)
Al Moodie
Grip
Need urgent your replies in order to change order if necessary.
“Am ordering Axioms
M22ti for front L/R,
VP150 for center,
and Q4s (Quadrapoles) for surround.
Sub will be PSB Subsonic 5.
Will the Denon 1802 be OK for this setup or should I move up
to the 2802 ? I would prefer not to spend the additional $$$ but
don’t want to buy the wrong receiver.
I do not plan on going to a 6.1 or 7.1 set up and I do not need
component switching (will go direct to TV with component).
Other than the component switching and a few more watts
(and maybe the remote) is there any good reason not to
stay with the 1802 ?
KevinGS
Hey Al,
I am using a Denon 1800 (75wpc 8ohm) with the M80, VP150 & QS8 (4,6,6ohm respectively) in a 10.5 x 27 x 7.5 room. I have no problems with the Denon putting out loud volumes.
I would think you should be happy with the 1802
Best of luck
kev
acinstallation240
