axiom wall bracket questions (1 Viewer)
William_Gravem
I just got my speakers, and am trying to set them up. I got Axiom M22's, VP 100, and QS 8's. The M22's and VP 100 are going to be mounted using Axiom's full metal bracket, which involves putting 4 wood screws in the back of each speaker.
I'm not handy and the idea of screwing holes into my speakers scares the crap out of me. Does anyone know what size screw I would need, or have any general advice? Would screwing holes into the back ruin the speakers? Am I just nuts for being so panicky about this?
Mort Corey
A call or e-mail to Axiom would seem the best route. I'm sure they can provide you with the proper sized screws and possibly some kind of template to make the job easier.
Mort
John Garcia
NorCal
I'm sure the brackets are designed such that they will not damage anything important in the speakers, but I would still NEVER screw into my speakers. Kiss your resale value bye-bye.
Personally, I would never wall mount something like the M22 anyway, I'd put them on stands to get proper positoning in the room.
William_Gravem
Resale value isn't a huge concern to me, but a big reason the M22's were so appealing to me in the first place was that they could be wall mounted using the full metal bracket. Maybe I should have gone with a smaller speaker...
But I'm still nervous that putting little holes in the back of the speaker is going to impact the way they sound.
William_Gravem
Thank you John.
Now, you also mentioned something about positioning. They're going to be a little high (the bottom of the M22 will probably be about 4.5-5 ft off the ground), but the brackets come with a thin wedge that can be used for slight adjustments to vertical angles. So, I was planning on angeling them downwards just a bit.
Does that sound reasonable?
John Garcia
NorCal
The tweeters want to be roughly at ear level when you are seated in your listening spot, so if the tweeters are higher than that (which they definitely will be), then yes, I'd use the wedge to angle them towards the listener.
JoeyT66
